Desktopbinder error
  • Voltage
    • Jul 2008
    • 282
    Desktopbinder error
    Hi Guys
    Yeah Yeah i still have a customer that uses desktopbinder
    For some reason when i want to print a doc in desktopbinder, the selected printer's properties are greyed out and i get an error message "device not supported" I have 4 pcs running DTB all in windows xp mode on windows 7 64bit machines. This is the ony one i can not get to work. Any ideas?
  • Wind Cool
    • May 2014
    • 82
    Re: Desktopbinder error
    Originally posted by Voltage
    Hi Guys
    Can you explain more details about " windows xp mode on windows 7 64bit machines" ????
    I did not understand.
    • Voltage
      • Jul 2008
      • 282
      Hi
      The customer is running Windows 7 64bit. Desktopbinder does not support 64bit so i setup windows xp mode (virtual windows xp) to run the desktopbinder in.
      Hope this helps
      • Wind Cool
        • May 2014
        • 82
        Hi
        Hope this helps
        Because your platform is under 64bit. So if you install a virtual 32bit Window XP under 64bit Window 7.
        It still won't work because your Kernel and Driver still under 64bit.
        You need to install a 32bit OS.
        • Voltage
          • Jul 2008
          • 282
          Hi
          I have 3 other pcs i have setup that works just fine. Its just the one pc.
          Something else i see is when i go to network places and click on view workgroup computers i get some kind of do not have permission error or something. Can not remember exactly. Do not know if maybe something is preventing the machines to communicate with the virtual machine
          • Wind Cool
            • May 2014
            • 82
            Hi
            I don't think is the user policy issue. It might be the Services in the Administration Tools see whether got any related service been OFF.
            • rthonpm
              • Aug 2007
              • 2853
              Check the VM and see if it's getting a private IP, or if it's pulling an IP in the same public range as the host machine and the MFP. It sounds like it's set for a private network with the host OS.
