A350 NIB
  • copytec
    • Aug 2025
    A350 NIB
    Hi guys,
    I have a problem with upgrade firmware for NIB 4.03F (A8555001H) for
    Aficio A350/A450 , A550 etc. printer controller.
    Firmware is upd file. Printer controller doesn"t recognize upd file from
    upgrade RICOH PCIMCI card (orig. card and orig. softwer)
    can anybody help me ?
  • Jomama46
    • 2900
    Thats a strange one, I have seen upd files in unix but not sure how to apply it to this nic. Hope someone comes up with the answer, I will check around it may be a command line update.
    sigpic
    A+; Network +; PDI+
    • FRIDGEMAGNET
      • Aug 2007
      • 377
      I belive this is done by FTP.
      Never had need to do it myself.
      There is a bulletin on it.
      • copytec
        Thank s very much!
        Yeah, experience is a power. I found on CD from april 03 MB about upd. file, but for
        this I need FTP Downloader. While I looking for FTP downloader on net (yes I know they are on TESSA), I found a NIB 4.03H version in bin. file, and I solve the problem with upd. file.
        Thanks once again.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          those old NIB's were very tempremental. Depends on which chip set you have. Also there's a trick to set the speed. When you web into the nib, use the ipaddress/speed to access the nib speed page. you won't get this through the normal web page.
          Mystic Crystal Revelations
          • copytec
            Thanks once again.
