What would cause what is shown in the picture? I replaced the drum a week ago and then this happened. I replaced the drum initially due to light copies and because of its age. The problem is intermittent.I swapped out the PCU unit with another charge roller, and I also cleaned all the grounds to the drum. This leads me to believe that the problem is either with the new drum, or with the transfer unit. Any suggestions or thoughts on this will be most helpful. Thank you.
