mpc 6000 sc 530
  • copierlady
    • 338
    mpc 6000 sc 530
    Hey guys. Working on a mpc 6000. Got a sc530 code. Replaced the fuser cooling motor. No change. Any advice for me? I am a Konica gal by trade. and I need some help here! Thanks
    • 37560
    Re: mpc 6000 sc 530
    Did you replace the front fusing cooling fan or the rear? Since SC 531 is the error code for the front fan, SC 530 is probably the rear fan. Also check the wiring harness for damage and check for air flow blockage. Dirty filters can some times cause SC 530 and 531. Goose's Guide has a number of additional items to check. If you don't have a copy of Goose's Guide, there are a couple of thread that have a download. Do either a Google search or a forum search. You can also email Paul@JustManuals.com.
    • copierlady
      • 338
      Re: mpc 6000 sc 530
      Thanks. Good info here. I think I replaced the wrong fan.
      • copierlady
        • 338
        RESET
        just replaced the rear cooling fan. still no luck. am I missing something about clearing the code? I went into sp mode then turned off the main switch. isn't that all there is to it on these machines? I also looked in the sp mode for a sc reset, but I don't see anything. Think i'm still stuck on the Konica guidelines and i'm missing something. I feel really stupid. I guess if all brands and models were alike we would eventually all be out of jobs.
        • ruben
          The New Guy
          • Oct 2012
          • 1204
          Re: mpc 6000 sc 530
          SC530 is a type B error code, it only needs the machine restarted and the problem fixed to clear. Make sure you are replacing the correct fan.
          SC530 - Fusing cooling fan error
          The VBCU did not receive the lock signal 5 seconds after the fusing unit fan switches on.
          • Fan harness disconnected or damaged
          • Fan blocked by an obstruction
          • Fan damaged
          From Goose's Guide:
          Product Family Problem Desc Solution Text
          D014/D015/D078/D079 SC 530 check wire harness from rear fusing fanto see if it contacted flywheel Replace vbcu and controller pcb
          D014/D015/D078/D079 SC 530 Fusing cooling fan error - check harness and connections
          D014/D015/D078/D079 SC 530 Fusing cooling fan error - Fan blocked by an obstruction
          D014/D015/D078/D079 SC 530 Fusing cooling fan error - Fan blocked, obstruction
          D014/D015/D078/D079 SC 530 Fusing cooling fan error - Fan damaged
          D014/D015/D078/D079 SC 530 Fusing cooling fan error - Fan damaged or defective
          D014/D015/D078/D079 SC 530 Fusing cooling fan error - Fan harness disconnected or damaged
          D014/D015/D078/D079 SC 530 Fusing cooling fan error -3rd duplex transport sensor harness (D014 5263 Harness) in duplexer is pinched blowing fuse 3 on VBCU.
          D014/D015/D078/D079 SC 530 Fusing cooling fans error - Inspect Fans M14 and M15 front and rear fusing fans
          D014/D015/D078/D079 SC 530 sub fuser fan was replaced # AX650042
