The control panel shows the green light for power, but never shows anything on the panel. The tech reseated all the connectors, but got the same results after powering on the machine. The power button on the control panel has no effect when it's pushed. Just the solid green light indicator for power.
This machine was originally called in for an SC386 error. We replaced the black dev unit a month ago for the SC386. The error went away but came back over the weekend. The tech pulled the dev unit out of the machine and noticed it was squeaky clean, same as it was when it was put in the machine. Service mode shows the pump for the black toner is activating. However, no black toner ever reaches the dev unit. Do the toner pumps go bad in these machines often? The machine has 900,000 total copies on it. All drums are new as well.
Thx.
Thx.
