Ricoh C4501
  • jdavis0613
    • Jun 2014
    • 2
    Ricoh C4501
    I have a Ricoh C4501 popping a sc565 code. Replaced pressure roller thermistor, pressure roller lamp and power supply. Does anybody know what else would be popping this code
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh C4501
    Move the fuser to another machine, if the code moves as well then it is the fuser, if not it could be a power supply or PSU problem.
    Check the continuity of the thermostats, sometimes they can cause some unusual errors. Also, check the temperature of the hot roller in SP mode.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Re: Ricoh C4501
      SC 565 PR lamp on full power - A level code, reset with SP5-810 3/25/2011
      SC 565 PR lamp on full power - check lamp with meter, replace as needed 3/25/2011
      SC 565 PR lamp on full power - check thermistor with SP1-106 3/25/2011
      SC 565 PR lamp on full power - replace PSU
      Mystic Crystal Revelations
        • 37507
        Re: Ricoh C4501
        I will go along with ruben on this one. Form experience, open pressure roller thermostat will cause pressure roller thermistor error codes.
        • TonerMunkeh
          Professional Moron
          • 3865
          Re: Ricoh C4501
          X2. 565 on these is a really shitty code and how a machine can run in the first place with a blown stat is beyond me, but they do.
          Hit it.
          • jdavis0613
            • Jun 2014
            • 2
            Re: Ricoh C4501
            Thanks guys. I will try the thermostat. I will let you guys know what I find.
