Ricoh Aficio 420dn Replace black PCU Message
  • Doug James
    • Jan 2012
    • 935
    [Error Code] Ricoh Aficio 420dn Replace black PCU Message
    Is their a way to reset this. The black PCU is OK. I have the manual but can't seem to find it. Any help is greatly appreciated. Thanks
  • Butrus
    • Jan 2012
    • 115
    Re: Ricoh Aficio 420dn Replace black PCU Message
    Execute 7804 002 in service mode
    • Doug James
      • Jan 2012
      • 935
      THANKS SO MUCH !!!
      • CableGuy
        Impulse Drive Engineer
        • Oct 2008
        • 417
        Sorry to Hi jack your thread, but on this subject can this be done for the 430's as well?
        Or switch off the message that pops up on the screen on this model.
        Customers don't buy the 'That Itb will last the life of the machine usually' routine.
        Cheers
        • Gift
          • Mar 2011
          • 2459
          I think you can entirely supress all maintanance display except toner/wate toner of course. Check the installation guide in the service manual, there should be an explanation about how to set up the machine for service contract usage. I think the impartant sp mode is called "meter click charge" - you can enable/disable and choose what units should/should not display life end.
          • CableGuy
            • Oct 2008
            • 417
            Thanks Gift, Will take a look. It's just a pain trying to convince customers that the machine will work fine without changing it, especially the ITB.
            Cheers
            • Gift
              • Mar 2011
              • 2459
              Yeah I know - you might just swap "something" and do the settings
