Hi Everyone,
I have a Ricoh MP C6000 that is dropping toner. When you remove the hopper and slide out the transfer belt there is a line of magenta toner going across the transfer belt the length of the imaging unit. I can clean off the belt unit but after a few days the toner build up again and gets on the copies / prints. This seems to be a common problem with this series as I have a 3260c that is doing the same thing on black. Is it the developer or cleaning brush?
Any help is much appreciated!!!
Mike
Mike
