Hi guys, today I have one big problem.
My Ricoh MP C2800 continually shows SC 367 error. SC367 error.
I have researched a little on the web, and it seems to be fault of TD sensor for Yellow color.
I have checked all wires and connections, and for me it's OK, and connects well.
MP C2800 is printing, but when you make a some amount of prints, error continues to appear.
I have discovered, that printer continually overload toner supply in Yellow Developer Unit.
Now it's pouring to much toner to DU.
Can you please help me to resolve this problem?
I have checked all wires with multimeter. And all good to go.
My friend technician says, that I must initial color registration, but I believe, that's not the case and will not resolve my problem.
I have found info (link bellow) that if is all connections works well, that I must change PCU.
I'm not sure, PCU means drum unit in this case, or what it means?
I have managed to enter SP mode.
In SP mode 3201 "TD Sensor V display", for Yellow is showing number: 0,16V
As I understand this value is too small? For BK M and C it's far more high value (above 1,6V)
So I have checked wires, connections, and now there is sugesttion: "Replace the defective PCU"
I don't understand how Yellow drum can effect TD sensor.
I have checked developer and Developing Unit, and for me it's good, and I have only printed about 170K color pages, so developer must be OK?
I have no changed yet Yellow drum and it's originally 170K from the start, I'm considering to change drum unit for Yellow in near future.
So my questions is:
Do you have any advice in this matter?
Could I initiate or set another settings in SP mode for TD sensor, that will fix this problem?
PCU - is drum unit, or what is PCU in this case?
My technician told me that, TD sensor is replaceable in DU, but he does not believe that TD sensor is fault.
I'm not very strong in this field, so I will appreciate any help or advice from You.
Main information I have googled is here:
Ricoh Aficio C2800 MP SC366 error - RICOH Copiers .... Error Codes, Problems & Solutions forum - Copier University
So my questions is:
