Aficio 2075 Loose's developer,not from bushings.
  • lary leon14
    • Oct 2008
    • 44
    I have a problem with a developer unit,that looses the developer.The bushings are ok,and it seem's that the developer come out of the magnetic roller.
    Also,i can not find any where else the developer.i tried to changed with another unit,and the problem keeps on.
    Anyone have the same problem?
    is there any advice solving it?
    Thank you!
    Who let the donkey out?
  • imihm
    • Feb 2014
    • 77
    Re: Aficio 2075 Loose's developer,not from bushings.
    Thank you!
    Hello
    This problem usually occurs when there is no proper bias applied to the magnetic roller ,please check it
    • imihm
      • Feb 2014
      • 77
      Thank you!
      Hello
      This problem usually occurs when there no proper bias is applied to the magnetic roller ,please check it..
        • 37432
        The problem can also occur when the machine is under toned.
        • imaginemoko
          unTrusted Tech
          • Jan 2008
          • 289
          development power pack perhaps is defective.
          fix the customer first then fix the machine... its simple and makes life more easy.
          • lary leon14
            • Oct 2008
            • 44
            Thank you for your answers,i will check the bias and the power pack of the developer unit,the machine,is not under toned.Thank you again!
            • Ronan
              • Aug 2011
              • 55
              Hi, check the axis of spent fridge or terminal which connects the bias which connects the unit to the hub broce contacts the shaft magnet of the developing unit, with that you know if you passed or not bias unit, make me how you did to us has passed us the same thing in several machines.
              • lary leon14
                • Oct 2008
                • 44
                I check the bias,is ok.i also check the toner,is not undertonered,but i clean the transfer inside,and it keeps working well till now,i will checked it again after a period to see the result.
                Thank you all of you for the replies!
                • aref1369
                  • Nov 2014
                  • 11
                  hello
                  1-chek the developer that is original
                  2-chek drum surface
                  3-chek discharhe lamps that is important
                  4-chek sial right and left of developer magnetic
