Hi all
I attended a Ricoh MP C4000 today with error SC582.
As we all know, these relates to a possible inverter coil/thermostat issue.
This error came 10 days after we installed a new fuser hot roller and pressure roller. We made sure we never went near the thermostat and left the printer working.
I have checked the coil thermostat and there is continuity so believe the coil thermostat is ok.
I have 220V at the PSU to Inverter but I don't get any voltage from the inverter to the Inverter Coil.
I also checked the fuser thermostat assy for continuity and they were fine. . .
Normally I would just replace the Inverter Board but wonder if the coil can take out the inverter board too. . . . .therefore requiring both the inverter and the coil???
I look forward to any help
