Alternate Developer for DSM745/35
  • PA3040
    • Jun 2014
    • 171
    Dear All
    DSm 745/35 Ricoh 3045/35 are discontinued
    Can any one have alternated developer for this model
    OEM part number B0799640
    Thanks in advance
  • mikadonovan
    • May 2008
    • 2931
    Re: Alternate Developer for DSM745/35
    I just googled "Ricoh 3045 Developer" and came up with several sources with OEM dev. Not sure what you are asking.
    NEVER ASSUME ANYTHING
    • PA3040
      • Jun 2014
      • 171
      Dear mikadonovan,
      Thanks for the reply
      Actually I asked other Ricoh developer that we can use 3045 without any issue
      • mikadonovan
        • May 2008
        • 2931
        I have used B140 developer from these guys with no real issues. Oem is still better.
          • 37529
          Are the machines DSm745/735 or are they DSm745e/735e? The "e" models use the same developer as the MP5000/4000. Part number B2969640. Also I have had no problem get the B0799640 developer.
          • PA3040
            • Jun 2014
            • 171
            Dear slimslob
            We have DSm745/35
            I used B2969640 with MP4000 toner ( filed the toner to bottler ) still testing but copy is bit light
            Actually What is the different between DSm745 and DSm745e
            Please advice
            • Eric1968
              • 2458
              If my memory serves me right, the e-version can do scan to folder. The engines are identical.
              • PA3040
                • Jun 2014
                • 171
                Are you sure e version can do scan to folder then I am sure both can
                  • 37529
                  Originally posted by PA3040
                  Dear slimslob
                  We have DSm745/35
                  Please advice
                  Formulation of the toner.
                  • PA3040
                    • Jun 2014
                    • 171
                    Do you mean on the bottle label
                      • 37529
                      I mean exactly what is in the toner and in what proportions. Different toner may have the same components in them but if the proportions are not the same you will have problems.
                      • PA3040
                        • Jun 2014
                        • 171
                        Dear slims
                        I am sorry since I am unable to provide component proportions today and i will update on Monday
                        Can you please explain what is the theory behind with following information
                        1.Development bias voltage
                        2.Toner
                        3.Developer
                        4.Drum residual voltage
                        5.Doctor blade gap
                        Eventhough deferment toner components, with Adjusting above 1 , 4 and 5 can we able to set proper image quality
                        Please advice
                        Thanks in advance
                          • 37529
                          Read the "DETAILED DESCRIPTIONS" portion of the Service Manual.
                          • PA3040
                            • Jun 2014
                            • 171
                            I will update this on Monday
                            Thanks for the information
