If it's the box I'm thinking it is check to see if it's one that was refurbed. Possibly has the wrong registration section in it altogether.
Anyway...it's time to think about it. All trays fail and I'll guess they all fail in the same place. Would that be just before or just at the registration section? The upper relay roller (shaft with the 2 big grey gears on it with B2 door) is driven by the bypass feed motor. Have you tried running a large number of prints feeding from the bypass tray to see if it jams in the same way? Probably won't as the bypass feeds paper directly to the registration rollers. However, if it does have issues jamming from bypass then maybe that's where it problem lies. I can't recall the linkage from the bypass motor to the upper relay roller (been seeing way too many Canons recently, Ricohs run reliably ;^)!!) but I don't believe it's clutch driven, more likely direct drive through gearing. Maybe the bypass motor belt is missing teeth, or the linkage between there and the upper relay motor has a gear missing teeth, etc., etc. You get my drift.
Otherwise, you could always try real estate again!!!!!
Note to self---next time make sure I've read all the responses to make sure problem hasn't already been resolved........
