mpc 2000 jaming at power on
  • lukeh
    • Jun 2012
    • 43
    [Jamming] mpc 2000 jaming at power on
    hi all
    was wondering if anyone has come across a simlar issue i am having on a mpc 2000 it jams intermitantly either before or after registration
    but it doesnt record it on the smc only sc/jam counter that increases is the jam at power on any ideas or answer to this issue will be great thanks
    i was thinking could it be the front door switches ? what does jam at power on mean?
    • 37529
    Re: mpc 2000 jaming at power on
    It means that a piece of paper was detected in the paper path when the machine was turned or when a door was closed. If the machine has am external finisher, the usual cause is the jam door switches on the bridge unit. Replace the switches and make sure that all firmware is up to date.
    • Eric1968
      • 2458
      I think it was 4 years ago. MP C2000 with intermittend jams. Turned out to be a bad push-switch for the waste toner container. These jams also do not show up on the jam history.
      • lukeh
        • Jun 2012
        • 43
        Thanks guys will check it out
          • 37529
          Possibly the same push switches used on the bridge unit?
          • Eric1968
            • 2458
            Exactly the same...
            • lukeh
              • Jun 2012
              • 43
              Ended up being push switch on waste toner bottle thanks
              • fredsp
                Product Specialist
                • Sep 2009
                • 14
                If the machine has a bridge unit installed check the bridge unit push switch as this is a known issue on them. At power on usually has something to do with a door switch or cover that is not making proper contact.
                • freginold
                  • Sep 2010
                  • 102
                  Also make sure the Engine firmware is up to date. one of the new firmware versions said something about changing the timing to reduce those bridge switch power on jams.
                  Config page instructions for copiers, printers, & fax machines
                  • Debs1964
                    • Oct 2010
                    • 1693
                    I never replace the push switches, I have always taken them apart and cleaned the grease from the contacts with alcohol, this method has never let me down
                    There are 10 types of people in this world, those who understand binary maths and those who don't
                      • 37529
                      I have a number of machines in a almond process plant. This method works fine for a temporary fix, but I have found that though it takes months for enough almond dust to get into the switches the first time, it only takes weeks after taking them apart and cleaning them. Also I tend to get a little clumsy working with small parts and have had to spend excessive time finding the spring when I drop one.
                      • Debs1964
                        • Oct 2010
                        • 1693
                        The advantage of having small hands
                        • pdpyen
                          Hello All,
                          Namaste from India!
                          I have been following this encyclopedia for more than 2 years now. (Sorry about them who dont know this)
                          I have a MPC2000 which had few issues earlier. I replaced the Thermistor in the fuser.
                          Eventually SC290 came up after that. After removing the shutter dust cover, it still showed up. Then I changed the presence to " NOt Present" via SP Mode.
                          Now, after that it worked flawless for around say 120 copies.
                          Then it started throwing SC792 at me, with the J001 paper feed issue at all A B C D.... (may be till Z if it had an option to).
                          I tried to get to the front door switch, and, cleaned all the contacts, checked them when they open and close. (Dint work)
                          Then i manually shorted the contacts(Front door switch cable) and checked if the machine would work. (Read on)
                          It did not. Meanwhile, i was searching for any solution on this issue. (Say some 10 mins were spent on copytech)
                          Now, it suddenly showed SC680-01. I restarted the machine.
                          The Machine started to load the toner, eventually i was relieved. (I thought so)
                          After the screen showed "ready", the machine again threw the paper jam error J001.
                          I'm unable to understand, as to what is really wrong in this.
                          This machine doesnt have a Finisher(SC792), but the SC code shows up citing paper jam error.
                          I've carefully observed the peper feed section, and there is no paper/bits/pieces which is causing the jam.
                          I'm here to seek you(Pro's) assistance to resolve this.
                          All the toners are 3/4th full.
                          Firmware 1.12V
                          Machine has done around 150000 black; 80000 CLR.
                          No Finisher/punching devices attached to it.
                          Please let me know if more details are needed, and i shall provide the same.
                          thanks
                          (If this reply is not relevant, please direct me to the appropriate section.)
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            [QUOTE=pdpyen;543916]Hello All,
                            Namaste from India!
                            Namaste from Belgium, too!
                            Fine that you follow this site. But I think that everyone will agree that you need ta start a new treat for your problem.
