Ricoh MPC3000 cannot scan to Windows 8 PC
  • muniandy
    #16
    Re: Ricoh MPC3000 cannot scan to Windows 8 PC
    Originally posted by richard lee
    May I know up to what size of SD Card can the Ricoh MP C3000 read? I can only find the smallest here is 4GB.
    Thanks.
    you can use 256mb sd card also to update
    • richard lee
      • Jun 2014
      • 13
      #17
      The original is 128MB. I tried the 4GB SD Card don't seem to work.
      The technology seem to be moving very fast.
        • 37495
        #18
        tis cutom firware for mpc 3000
        Posting of firmware could be a violation of general 5 of the Forum Rules. Don't be surprised if an Administrator, Moderator or Donor/Contributor drops a red card on you. You are new to the forum. Pick up too many red cards and no Rep Power and the older experienced techs might not be interested in helping you with a problem.
        • jabatt
          • Apr 2014
          • 15
          #19
          리코 mpc3000는 윈도우 8 pc로 스캔 할 수 있습니다
          mpc2500,mpc3000,mpc3500,mpc4500 윈도우8에서 스캔할수 있습니다.
          두달전 한철안 사장이 펌웨어를 구해 달라고 해서 구하던 중에 여러 경로를 통해서 구할수 있었습니다.
          하지만 구해 달라던 사람이 내가 가진 데이타를 믿지 않는 관계로 빛을 보지 못하고 있습니다.
          • richard lee
            • Jun 2014
            • 13
            #20
            sorry I don't understand Korean. My PC translated as:-
            ' Ricoh m p c 3000 you can scan your pc for Windows 8, mpc2500, mpc3000, mpc3500, you can scan from Windows 8 mpc4500. A couple of months ago and should not have an iron to get the boss firmware SEO during the multiple paths available through the. But I have to get a different person who does not believe the data in relation to the light. '
            • craigchowles
              #21
              Hi Newbie here,
              My customer upgraded some of their PC's to windows 8 and now cannot do scanning from Ricoh MPC3000 to PC. However, scanned to Windows 7 Pc's are fine.
              The error pops out after completed scanning.
              Is it firmware issue?
              The MPC3000 is too old to scan to windows 8. Ricoh never released and firmware for the problem
              • teebee1234
                • Jul 2008
                • 1670
                #22
                If the customer will let you, one can disable smb2/3.
                Windows 8 and Windows Server 2012
                Windows 8 and Windows Server 2012 introduce the new Set-SMBServerConfiguration Windows PowerShell cmdlet. The cmdlet enables you to enable or disable the SMBv1, SMBv2, and SMBv3 protocols on the server component.
                Notes When you enable or disable SMBv2 in Windows 8 or in Windows Server 2012, SMBv3 is also enabled or disabled. This behavior occurs because these protocols share the same stack.
                You do not have to restart the computer after you run the Set-SMBServerConfiguration cmdlet.
                • To obtain the current state of the SMB server protocol configuration, run the following cmdlet:Get-SmbServerConfiguration | Select EnableSMB1Protocol, EnableSMB2Protocol
                • To disable SMBv1 on the SMB server, run the following cmdlet:Set-SmbServerConfiguration -EnableSMB1Protocol $false
                • To disable SMBv2 and SMBv3 on the SMB server, run the following cmdlet:Set-SmbServerConfiguration -EnableSMB2Protocol $false
                • To enable SMBv1 on the SMB server, run the following cmdlet:Set-SmbServerConfiguration -EnableSMB1Protocol $true
                • To enable SMBv2 and SMBv3 on the SMB server, run the following cmdlet:Set-SmbServerConfiguration -EnableSMB2Protocol $true
                • sandmanmac
                  • 3981
                  #23
                  "Custom Network firmware" was created for many of the older boxes. (Foolishly posted on the previous page of this thread)
                  • peterxu256
                    • Jul 2014
                    • 110
                    #24
                    Whatever machine mode it is, They all work Very Very well with Windows 7, why not windows 8?
                    Current situation is most of customers who is still using windows XP or 7, a few of them is using windows 8. If firmware modified to adopt for win8 users, how about older version users since SMB is not compatible backward. How confused it is.
                    • sandmanmac
                      • 3981
                      #25
                      Don't over complicate this.
                      Firmware update is required to work with the new SMB protocol used in windows 8. All machines will continue to work with previous versions of windows after the update
                      • peterxu256
                        • Jul 2014
                        • 110
                        #26
                        Have you read the following article posted by Microsoft?
                        http://support.microsoft.com/kb/2896636
                        http://support/microsoft.com/kb/2887595
                        I did installed the patch KB2896636, it seems don't work either.
                        • Klaus Joergensen
                          • Mar 2013
                          • 5
                          #27
                          Ricoh Germany: there will be no Firmwareupdates for MPC2500/3000.
                          Now we use Filezilla FTP-Server on Server 2012 and it is working fine.
                          • Tonerbomb
                            AutoMajical Resolutionist
                            • Feb 2005
                            • 2589
                            #28
                            Filezilla has been a great work around for several years now, not just for win8...............
                            Mystic Crystal Revelations
                            • richard lee
                              • Jun 2014
                              • 13
                              #29
                              Hi,
                              Anyone got a step by step guide on this filezilla setup for scanning or is there a link to download?
                              Thank guys.
                                • 37495
                                #30
                                Hi,
                                Thank guys.
                                FileZilla - The free FTP solution for both client and server. Filezilla is open source software distributed free of charge.
