MPC2800 web page no display
  • MadMatt
    • Mar 2008
    • 7
    Hi
    I have a MPC2800 which I cant access the web page, been into the network card and its set to 1, which is ok been told 2 is print but no WIM access?
    Any one had this??
    Cheers
    Matt
    sigpic
    I T / Copier Engineer
    M C P 2000 / 2003
  • ptrflrs
    Glorified Parts Swapper
    • Dec 2010
    • 192
    Try connecting your laptop directly to eliminate the network. Also check firmware. Can u print to it via ethernet?
    jesus loves you! (everyone else thinks you're an assh*le)
    street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
    Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
    • sandmanmac
      • 3983
      Re: MPC2800 web page no display
      Check that SP5-828-091 (Web) is set to 1 (on)
      Failing that, you could try an NCS clear (SP5-801-011)
        • 37553
        Check the security setting in user tools. Certain security settings will block WIM. Look in the security manual usually found on the manuals disk.
        • MadMatt
          • Mar 2008
          • 7
          Cheers network security was set to level 2 set it to 0 and I can gain access
          Cheers.
          Thanks for your help
          sigpic
          M C P 2000 / 2003
