MPC4500 SC990
  • Elmo
    • Feb 2010
    • 541
    MPC4500 SC990
    Hi All
    I have an mpc4500 that throws up sc990 at start up
    ive updated the firmware replaced the HDD's and even replaced the controller
    but still get sc990
    iam going back with new memory and nvram to try
    any advise would be much apretiated
    I Used To Live To Fix Things Now i Fix Things To Live
    • 37491
    Re: MPC4500 SC990
    Check the PM counts on all the drum units and development units. Black and whites used to throw SC990 when they were too far past a PM.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Re: MPC4500 SC990
      Originally posted by Elmo
      Hi All
      but still get sc990
      What kind of shape is the rest of the machine in? Drums transfer ect. Are there any other codes logged ??
      Mystic Crystal Revelations
      • Elmo
        • Feb 2010
        • 541
        Re: MPC4500 SC990
        The machine is in average condition the customer bought it second hand over a year ago
        it was not supplied by myself i just got a callout to repair it
        drum units are near end of life fuser and transfer past life
        customer said machine was working one day then next morning switched on and got sc990 machine hasnt worked since
        only errors in log are 5 x sc990
        going back on monday will let you know if i get any further
        going to take a psu just incase
        • kannuki2
          • Feb 2012
          • 398
          Re: MPC4500 SC990
          Do the machine have any type of Java VM or Browser options? make sure you update it to the latest version. I ran into this issue multiple with the new machines.
          • Elmo
            • Feb 2010
            • 541
            Re: MPC4500 SC990
            thanks for all the help
            was a bit of a strange one removed the print scan sd card and got the sc990 to clear
            but machine showed door open constantly
            turned out to be the psu replaced it and the machine all working
            then found out from customer they had had a power cut to the building
            and when they got the power back thats when the machine was faulty
