Mpc 5501 front cover open
  • ash_572
    • Oct 2008
    • 523
    I changed both front door switches with no joy.
    In input check 5803-38 interlock release detection 1 changes signal but 5803-39 interlock release detection 2 does not change signal. Right side door signal changes fine.
    Very strange random problem I have here. Sounds like a board problem
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Mpc 5501 front cover open
    are you able to inspect the PS?
    Nobody is perfect..
    • ash_572
      • Oct 2008
      • 523
      The power supply? Yes
        • 36833
        I think that there is a third switch for the front door. Item number 19 on the attached.
        Frame.pdf
        • ash_572
          • Oct 2008
          • 523
          [ATTACH]25644[/ATTACH]
          Isnt that the main on/off switch?
            • 36833
            It looks like it is mounted on the upper right of the front frame. With the way the parts catalogs are, it could be it could actually be on the lower left of the rear frame in which case it is the main switch.
              • 36833
              I downloaded the parts finder and by rotating the view it is the power switch.
              • ash_572
                • Oct 2008
                • 523
                Fixed.
                it was the PSU. Thanks everyone
