Ricoh MPC2551 Noisy Fuser??
  • Leebs14
    • Feb 2014
    • 457
    I have twice now been to a MPC2551 which when warming up or in pre-drive or after a copy cycle makes a horrible clicking noise. the strange thing is it doesn't make it when the paper is actually going through the machine. I have lubricated the fuser bearings and checked the drive gears which all seem free and easy to turn. Its definitely coming from the fuser unit and I thought I would ask the question if anyone has come across this before and how they fixed it before I order an expensive fuser unit.
    Thanks guys (and girls)
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: Ricoh MPC2551 Noisy Fuser??
    it is not the gear causing that sound it is a friction on the belt unit assy. Disassemble the belt unit then lubricate the edges or better replace it.
    Nobody is perfect..
    • CSI
      • Oct 2008
      • 73
      Check the picture : pic24191.jpg
      Sorry for quality :
      SP1-121-001 : [100] -> [0]
      SP1-121-002 : [10] -> [0]
      SP1-121-003 : [10] -> [0]
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        What is the fuser sleeve PM? They wear down really easily and should be replaced. You can also use the optional oil supply to get around some noises, but it only works a short while.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          Check those settings that CSI posted up...they work.
          • ruben
            The New Guy
            • Oct 2012
            • 1204
            See also attached tech bulletin (RD104036) for another fuser noise problem.
            rd104036.pdf
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              This is nothing new......search the forums there are posts for this already..................
              Mystic Crystal Revelations
