c6055 with a toshiba es7030c pro model on it
  • Valintine
    • Jan 2012
    • 147
    Hello
    I have a copier that I think is a Savin family machine with a Toshiba name on it. It is the Toshiba es7030c pro. I think it is the savin c6055 but am not positive. Here is the question I have.
    I bought a used machine for a customer. It came in with a fiery button but when I press it it says loading but never loads. Can I either bypass and print using the regular lan port or am I missing something? I did notice that the two sd ports do not have cards in them. It has been a long time since I have seen this model and thought the cards need to be there. Can anyone verify this for me?
  • Valintine
    • Jan 2012
    • 147
    Re: c6055 with a toshiba es7030c pro model on it
    Hello
    I have been able to verify that the Ricoh cross to the toshiba is mpc 7500. Does anyone know where I can buy the sd cards for this model?
    • TonerMunkeh
      Professional Moron
      • 3865
      Direct from Ricoh would probably be best, however:
      Ricoh Printer Scanner Unit Type C7500 | eBay
      With it being a Tosh box I don't know if there will be custom / bespoke firmware on this thing to make it ignore standard Ricoh cards.
      Hit it.
      • Iowatech
        Not a service manager
        • 3930
        Still, could Valintine hook the machine up directly to the network and print that way?
        Sorry, my total knowledge of Fiery is being able to identify the logo (well, at least three out of four times correctly anyway) and being able to carry the interface if it is still in a box, so I don't know.
          • 36833
          Unless it has embedded print/scan, it does need the SD card in order to print. You should be able to bypass the Fiery.
