SC144 after PM service?
  • fatfingers73
    • Feb 2013
    • 219
    Hello,
    Did 600k service today on two pro 5100's.
    One of them is throwing up this code, and the scanner doesn't light up or move when I start the machine.
    Not sure what I touched that can cause this?
    Just after some advice before I order a new board.
    Thank you
    • 37556
    Re: SC144 after PM service?
    Have you followed the trouble shooting in the service manual? Most likely you knocked a connector loose and did not get it fully reconnected.
    • fatfingers73
      • Feb 2013
      • 219
      Yes I tried all that. Wasn't anywhere near that area though, very strange.
      Also can't find SBU board in parts manual. Can you help?
      Thank you.
        • 37556
        Thank you.
        SBU - Sensor Board Unit. The board that is mounted to the back of the lens block. If it is bad, you have to replace the entire lens block. There is a cable that goes from it to the IPU, Image Processing Unit, board. Check that cable.
        • fatfingers73
          • Feb 2013
          • 219
          Yesterday was a long day.
          Realised I was trying to add new dev before fitting faceplate!
          Nothing to see here
