MP C3500 Jam won't clear
  • tomski0
    I have a MP C3500 that is indicating a jam at location "c". There is no paper there and i can't get it resolved. I have replacer the following. ( Fuser,Fuser conector,BCU,I/O,IPU,paper exit sensor,fuser inlet and exit sensor,the sensor in the secondary transfer box,cut all wire ties within the area,push button switch on right hand door and the front door switches.)none of these made any change.
    Please share if anyone has experienced this before.
    Tom
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MP C3500 Jam won't clear
    What does the Logging Data say?
    • L-IQ-uid toner
      • Mar 2014
      • 17
      How about using input tests for all the sensors and switches in that area?
      • Captain Scott
        • Dec 2008
        • 166
        If you power up the machine with doors open does the message appear only once you close them. What is the jam location number? Have you tried an engine clear 5 801-02?
        • mikadonovan
          • May 2008
          • 2931
          This tells you which sensor is detecting a fault.
          This will tell you if it's bad/blocked.
          NEVER ASSUME ANYTHING
          • Old Sergeant
            • 16
            Had this on other models that turned out to be door switches gone bad. Machine doesn't know the door closed so won't clear the jam message. Do input tests on door sensors to determine if any show open doors.
            • tomski0
              when the machine is powered up the jam comes up immediately. I have done an engine clear and replaced data from the birth certificate, i have checked both door switches as well as fuser entrance and exit,transfer and the 2 for the inverter guide sensors. these were checked in I/O mode as well as ohmd and voltage checked. The firmware has been updated and nvram has been backed up and cleared.
              The plotter history showed a J005 fir the last jam when this problem arose, which is the lct. I have taken the finisher,bridge and lct out of the equasion.
              Tom
                • 37398
                This means that either the cause of the jam has not been corrected, or that the door necessary to clear the jam indication has not been opened and closed.
                Even though you have the birth certificate, never do an engine clear unless instructed to do so by Ricoh Technical Support. There is no type of memory clear that will correct a paper jam indication.
                Tom
                If by taking them out of the equation you mean that you removed or disconnected them, that will do nothing if the machine thinks it has a jam. You have to clear the jam first. For a J005, tray 3 non feed, you have to open and close the jam door on the LCT or Paper Bank which ever you have. If you have not done that or if the machine does not detect the door as having been opened and then closed, the jam will not clear. Some models also require you to open the front door, even it has no access to the jam.
                Try turning the machine on with the jam door open. If the machine does not indicate "Door Open", the door switch is bad.
                • imaginemoko
                  unTrusted Tech
                  • Jan 2008
                  • 289
                  Sir have you check the paper exit unit assembly? sometimes a faulty sensor there due to toner dusting or even wornout due to fusing heat and the ages maybe... best of Luck Sir.
                  fix the customer first then fix the machine... its simple and makes life more easy.
