Duplex issue
  • Dyzzlle
    • May 2025
    Duplex issue
    The duplex of my ricoh aficio 1224c is not being detected by the system even after firmly connecting it's cable. What may be the possible causes for this error and how can it be corrected. Help please.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    You could have a faulty duplex controller.
    I assume the duplex was working fine prior to this occuring.
    1. Check the duplex connector on the machine for bent pins.
    2. Check the wire harness for visable damage and reseat the connectors on the duplex controller.
    3. Use a multimeter and check pins 1 and 3 / 9 and 11 on the machines connector for +5v output.
    • Jomama46
      • 2900
      When you say, "not detected". Is it not showing an an option of the screen, or does it not show on the printer config sheet or as an option in user tools.
      Did you reboot the machine after you plugged the duplex in.?
      sigpic
      A+; Network +; PDI+
      • FRIDGEMAGNET
        • Aug 2007
        • 377
        Not sure if this is the case but if the HDD went down, would you loose functionality, including duplex.
        • Jomama46
          • 2900
          You would for sure loose functionality and it would not show on the LCD but it would show up in the printer config page.
          sigpic
          A+; Network +; PDI+
          • NCArt
            Mountain Tech
            • May 2008
            • 81
            Defenately look at the HDD...I had one with a bunch of bad sectors and wouldn't let the duplex show on the screen.
            • Cipher
              • May 2006
              • 1309
              I forgot all about a faulty HDD causing limited functionality, yes that is more likely.
              • Ollie1981
                Toner Monkey
                • Mar 2008
                • 418
                Does it spin the motors when you start the machine?
                Also the "hotkeys" for the various duplex options do not appear automatically, you'd need to add them in user tools, do you not get the duplex/combine key at the bottom?
                A bad HDD is probably a good candidate, check the SMC for HDD SC codes
