pro c901s sc 919
  • salmandol
    • Mar 2009
    • 107
    pro c901s sc 919
    Good day all. We recently obtained a used Ricoh pro c901s with a fiery e-81 that gives a sc919 when you send a print. I was wondering if this model needs a USB dongle as we did not receive any with it. Could this be causing this error?
  • PinevskiS
    • Jul 2009
    • 283
    Re: pro c901s sc 919
    You have problem with patches download of ricoh site and install.
    • salmandol
      • Mar 2009
      • 107
      i installed the patches and still getting sc 919. the machine still cannot print any type of file. Any other ideas
      • RG1964
        • Jul 2009
        • 56
        Check the server configuration. I think you have a problem with the APPE Adobe print engine. It's on the last tab of the configuration page. You better not select the second option on this page. Or print the pdf file throug pdfcreator. And try to print it again.
        • salmandol
          • Mar 2009
          • 107
          I did a full re install of software and problem was solved. Thanks
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            Which Fiery do you have??
            Mystic Crystal Revelations
            • PinevskiS
              • Jul 2009
              • 283
              [QUOTE=Tonerbomb;433514]Which Fiery do you have??[/QUOTE
              Fiery E 81
