error sc547 in ricoh spc811dn
  • BATA
    • Mar 2012
    • 27
    hello, that error code sc547 for ricoh spc811dn, i replaced the heater unit same problem , what other i have to replace and where i can find them
    in the machine thank you
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: error sc547 in ricoh spc811dn
    Did you reset with SP5-810? If not, do that first before replacing anything else.
    From Goose's Guide:
    SC 547 replace PSU
    SC 547 SC 547 - problem in fuser unit, check for shorts etc
    SC 547 SC 547 - replace PSU
    SC 547 SC 547 - reseat CN 221 pin 2 on IOB and CN 909 pin 6 on PSU
    SC 547 Zero cross error - A level code, use SP5-810 to reset
    SC 547 Zero cross error - problem in fuser unit, check for shorts etc
    SC 547 Zero cross error - replace IOB
    SC 547 Zero cross error - replace PSU
    SC 547 Zero cross error - reseat CN 221 pin 2 on IOB and CN 909 pin 6 on PSU
    SC 547 Zero cross error - reseat CN-221 on IOB
    SC 547 Zero cross error - reseat CN-909 on PSU
