SAVIN 4045Esp Photocopier Machine error code Problem
  • Mahmood ul Hussan
    [Error Code] SAVIN 4045Esp Photocopier Machine error code Problem
    Aslam o Alaikm
    Dear Friends m New here i have a photocopier machine that is SAVIN4045 Esp i have many error codes but i solve but now it cant work it shows J001 error code,sc322,sc329 error codes and when i try to print a copy it cant print the paper fix into the machine and machine shows SC329 functional problem Main Power Switch off then on and so on what is this matter m realy confused if any expert is here plz help me yar m so poor and needy if you help the Poor and needy God will help you ....................Waiting for answer
    Thanks........................(Fi Amaan Allah)
    • 37532
    Re: SAVIN 4045Esp Photocopier Machine error code Problem
    The machine has a problem with the laser diode unit. SC 322 is a first laser sync detect error. SC 329 is a laser beam pitch adjustment error. Follow the laser pitch adjustment procedures in the service manual.
    • rthonpm
      • Aug 2007
      • 2859
      Be sure to also check the three door switches that are in front of the fuser on the top right side of the front panel. If they get dirty or contaminated you can get laser error codes and the jam codes that you are seeing. This model runs very dirty so laser issues and dirty door switches are both quite common.
      • laitang
        • Nov 2012
        • 627
        sc329: LD unit beam pitch adjusted incorrectly
        After initialization of the SP modes, SP2-109-3 or SP2-109-4 was not executed.
