Windows 7 Scan to Folder SMB Do I need to update Firmware.... Thanks
+ More Options
Posts
  • sagar4
    • Dec 2012
    • 127
    [Error Code] Windows 7 Scan to Folder SMB Do I need to update Firmware.... Thanks
    Good morning fellow Techs. I have a Ricoh 3035 and a customer that just finally updated there computers from win XP to win 7. I have attached the config page by looking at the config page do I have to update the firmware to get it to work on win 7. I am more of a Xerox and Toshiba tech but do like working on Ricohs I just never updated a firmware on one before. And also if it does need an update of firmware would you be able to supply that to me through dropbox. And yes I can pay if I have to. I just keep getting an error message after setup. Thanks
    "Broken again"
  • halbrandenburg
    Bypass Tray Expert
    • Sep 2011
    • 92
    Re: Windows 7 Scan to Folder SMB Do I need to update Firmware.... Thanks
    Here is a document that can help. Windows 7 64 BIT can be quite strict. I would suggest giving an exact user permissions to the share and in the security settings of the folder, and not just the EVERYONE object. Usually the 128-BIT Encryption and Home Group setting might be the culprit. I've used this doc for several years.
    Strongly doubt if firmware is the issue here, but you do not have much detail in what you are running into.
      • 37629
      Since you do not mention what the error was we can only guess what the problem is. The 3035 is new enough that it should support Win 7. Firmware history does not show any updates for Win 7. When using SMB to scan to Win 7, you do have to use an authentication name that has a password. If the computer user does not like to have to enter a password every time he/she turns on the computer, do a search for automatic login for Win 7.
      • sandmanmac
        • 3990
        Why not just do the easiest thing and setup FTP? It's neither OS nor firmware dependant, and it just plain works.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          FIlezilla is a free FTP client!!!!!
          In win 7 you can make life easier by turning off password protected sharing................
          Mystic Crystal Revelations
          • halbrandenburg
            Bypass Tray Expert
            • Sep 2011
            • 92
            I do this if SMB does not cooperate. I agree, it withstands Microsoft Updates and password changes. I use Filezilla Server often for FTP. As the tech you have more control too.
            • mikadonovan
              • May 2008
              • 2931
              Yes, you do need to update the NIB firmware to 5.12.5 (B7835934K, Sept 2010 release).
              NEVER ASSUME ANYTHING
              • sagar4
                • Dec 2012
                • 127
                Ok thank you all for your input. I will return to forum and let you all know what took care of this situation. Thanks again
                "Broken again"
                • sagar4
                  • Dec 2012
                  • 127
                  Okay I have tried all the above except for the firmware. So if anybody can give me the firmware or know where I can get it from and of course I can pay for it also. Thanks
                  "Broken again"
                  • sagar4
                    • Dec 2012
                    • 127
                    Do you know where I might be able to get the firmware either for free or purchase. Thanks
                    "Broken again"
                    • arjun
                      Thanks a lot, this PDF document helped me a lot to configure Windows 7 64bit SMB connection .
                      • Codex
                        • May 2008
                        • 705
                        Hello
                        in some cases Scan2Folder doesn't work even if you made a Firmware update, try to setup the path to your shared folder manually (\\computername\foldername) instead of network search , in my case it worked !....
                        Memento Audere Semper
                          • 37629
                          Originally posted by Codex
                          Hello
                          In order for browse the network to work, you have to be on the same Domain as the network or the same workgroup name if peer to peer. You also have to be sure that the first DNS is local, especially on a domain. In some instances, I have had to both setup the domain name and an SMB work group name.
