rebuilding a mpc 2800 fuser
  • fshead
    • 2378
    hi
    i am rebuilding my 1st mpc2800 fuser unit and was wondering if the were any tips.
    im doing the full kit and will change everything.
    the thermister looks good as do the gears..
    has 250k and the fuser belt is frayed on the rear side..
    its in my shop as i just bought this to resell
    thnx
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: rebuilding a mpc 2800 fuser
    It is almost the same as a MPC2000-3000 fuser, just a bit bigger.
    Check the pressure roller drive gear; these can crack. Check the clutch gear; these can collapse. Also, check the foam roller, if it is damaged around the shaft it will need to be replaced.
    • Eric1968
      • 2458
      The Pressure Roller Bearings need a bit of heat resistant grease to prevent that rattling noise during printing.
        • 37649
        My rule of thumb when rebuilding something that I have done before, follow the service manual, step by step.
        • Debs1964
          • Oct 2010
          • 1693
          Me too, that's what the manual is for, and you can save yourself a lot of heartache, once you know the correct procedure, then it's possible to look for shortcuts
          There are 10 types of people in this world, those who understand binary maths and those who don't
          • Gift
            • Mar 2011
            • 2459
            I usually do the kit + press roller thermistor. If no long time solution is needed I try cutting some costs and just replace the defect parts.
            • fshead
              • 2378
              thnx all will check all advised here and the small parts too,
              read some of the manual but rather print out the pages and have
              as i pull it apart.
              have two mp6001 i have to prep first
              • Klydon
                • Mar 2009
                • 243
                Honestly, these are one of the better fusers Ricoh has come out with. 250K is just breaking it in for the most part. I have had them go 500K+ before without issues.
                The advice given by other posters is spot on in terms of checking/replacing the gear and also greasing the bearings.
                Don't be so fast to assume on the thermistor on the heat tube (the one with the belt). I have had a fair number of these that do need to be changed from time to time or you wind up with 543 codes. With 250K on it, I would not change it, but this is more of a FYI than anything.
                • fshead
                  • 2378
                  thnx
                  the belt on this one looks good except for a piece ripped or torn on rear side.
                  i bought the complete kit and will do a complete rebuild ..saw no heater codes in sc history so
                  will just chng pm parts.
                  • dapost
                    • Apr 2011
                    • 4
                    Re: rebuilding a mpc 2800 fuser - pressure roller gear
                    I can not seem to identify the pressure roller gear in the MPC2800 MPC3300 parts manual.
                    Does anyone know the part no.?
                    If I am correct, the pressure roller is the black roller with one lamp, outside of the belt.
                    • dzewo
                      • Oct 2013
                      • 36
                      Part no. AB014308 I suppose.
                      Question about the life expectancy of all fuser bearings. How long can they last? Do you replace them when the fuser hits ~250k or they start to rattle?
                      • fshead
                        • 2378
                        i usually have the whole kit and change everything.
                        then save parts that look good in a marked used box..
