Java doesn't change status
  • swcopiadoras
    • Sep 2013
    • 18
    [Misc] Java doesn't change status
    Hi everyone!
    Does anybody see this case before? i have a Ricoh SP 5210 SF , and i need to embedded papercut mf for the project . but i can't install it because java doesn't start properly on the machine , the button "other functions" on the MFP doesn't work , on the web the status of java vm card is always "waiting" . I've changed the vm card , but the issue continues . Anybody could help me?
    • 37583
    Re: Java doesn't change status
    I think it is waiting for someone to start it. Have you tried clicking on the Selection circle in front of it and then clicking Startup/Stop? The status should change to either Starting Up or Stopping.
    • swcopiadoras
      • Sep 2013
      • 18
      I've already did it, they stop, but when i click again the message "waiting" appears again...
        • 37583
        Have you tried accessing from the control panel?
        • swcopiadoras
          • Sep 2013
          • 18
          Same problem
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            once you select start up or stop in the java menu, you have to reboot the machine to have the change take effect. Now for the extended application, It has to be installed and have java running to work with any desktop software. There should be an install guide for papercut, that probably assumes java is already installed and running............
            Mystic Crystal Revelations
