Lcc installation instructions
  • Valintine
    • Jan 2012
    • 147
    Hello
    I have a Richo 7500 with a Toshiba label on it. I am trying to install a lcc on the side. It looks like the bypass needs to come off the machine to install it but when I take it out there is a void area. Do I remove parts from the bypass or is there a bride type of part I need to get?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Lcc installation instructions
    It's all in the service manual.
    LCT (B473) installation: lct.pdf
    • Valintine
      • Jan 2012
      • 147
      Hello
      We just found the model number of the lcc is LCIT RT4000 (D350) Looking at installation instructions I am missing the relay unit. Does anyone have the part number for it or one for sale?
      Thank you
      • Valintine
        • Jan 2012
        • 147
        Here is a couple of pages showing the part I need. Any help would be appreciated.D350 relay section.pdf
        • laitang
          • Nov 2012
          • 627
          Here you are:
          RT4000 (D350)_Installation.pdf
            • 37513
            Originally posted by Valintine
            Hello
            Thank you
            If you are trying to put a LCIT RT4000 (D350) onto a MP 7500, which is a B/W MFP, it won't work. The D350 is for the color MFP, MP C7500. The LCT for a MP 7500 is the RT43 (B473). Specifying the proper model and type, color or B/W, allows us to better help you.
            If you do have a MP C7500, the bridge unit come packed in the accessory box with the rest of the installation accessories. The attachment that you included shows where the accessories box should be packed. If you do not have the accessory box, contact whoever you got the LCIT from as you most likely do not have any of the installation accessories. SM-rfg031008.pdf
            • Valintine
              • Jan 2012
              • 147
              Thank you for the reply. I have the Toshiba version and it is color. I left the the c off. This is a used option and the part most likely is on the copier it came off of. Is there anywhere I might find either the part or the kit?
                • 37513
                I did a quick check of the parts catalog for the LCIT and the installation accessories are not listed.
                • laitang
                  • Nov 2012
                  • 627
                  .....Is there anywhere I might find either the part or the kit?
