Copying Checks
  • halbrandenburg
    Bypass Tray Expert
    • Sep 2011
    • 92
    Copying Checks
    I found that yesterday on a C3003 if I set the zoom at 65% I could copy a secure check in BW or color.
    Some customers don't care at all that copying checks is illegal, and are livid when they upgrade to a new copier. I think you can also blow them up a bigger size and make it work too.
  • rthonpm
    • Aug 2007
    • 2859
    So long as the size is large enough or small enough that there could be no confusion about the copy you're able to reproduce it. I always called it the Play Money rule: if you can find play money in that size the machine will let you do it.
    --sent from my BlackBerry using the Android app
    • halbrandenburg
      Bypass Tray Expert
      • Sep 2011
      • 92
      Re: Copying Checks
      The two checks I worked must have had VOID embedded in the pattern. It did not show up to the naked eye, but printed all over the check when the copy was made.
