ricoh MPC 4500 SC 492
  • reunited
    • Apr 2014
    • 5
    [Error Code] ricoh MPC 4500 SC 492
    Hi,
    Trying to fix my customer MPC 4500 with SC 492 code. Already change the fans but the code still come back after some time. Pls help.
    Thanxs
  • Polo-022
    • Sep 2007
    • 486
    Re: ricoh MPC 4500 SC 492
    This is a High Voltage Power supply error at Image Transfer unit.
    • laitang
      • Nov 2012
      • 627
      • adoug
        • 23
        Originally posted by reunited
        Hi,
        Thanxs
        Hi
        I had this twice already.
        When you remove the transfer belt unit.
        Remove the belt and check the contacts.
        I had the contact for the black charge roller within the transfer belt unit break causing this error.
        Hope this helps.
