MPC 2500 fusing problem??
  • Codex
    • May 2008
    • 705
    Hello, i have a problem with an MPC 2500, when i print A3 from bypass or paper tray at the end of the copy there are kind of "lightnings"... I know a similar problem at b/w machines when the fuser entrance guide is dirty and the paper wasn't fed even..... Look at the attached picture please. Changed the entrance guide, bearings, pressure roller, fusing belt..... Any ideas?... Thx!
    Memento Audere Semper
  • Gift
    • Mar 2011
    • 2459
    • Eric1968
      • 2458
      Re: MPC 2500 fusing problem??
      Could also be a scratch on the Fusing Belt.
      • mikadonovan
        • May 2008
        • 2931
        That sure is what it looks like, but he said he changed the belt.
        NEVER ASSUME ANYTHING
        • Herostrat
          • Oct 2012
          • 220
          There is no toner on that wrinkle...it happened before fuser,check transfer corona if it's housing is leaning on transfer belt propperly.
          Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
          • skynetto
            • Sep 2012
            • 257
            Have you checked thw idle drive gear of the fuser? That one falls apart just by looking at it.
            • Coolnorth
              • Aug 2014
              • 5
              Are the fuser pressure release arms (activated by the right door) moving properly? Sometimes these get damaged, the clear rollers fall off, they get loose enough to not align with the door...I can't tell for sure if your sample is wrinkled as well as the toner missing?
              Graham
                • 37562
                There is no toner on the color background. There is black on the letter "a". Check the ITB and PTR.
                • Codex
                  • May 2008
                  • 705
                  Thx for the answers. I changed the fusing belt., but still same problem. When i stop the machine during copy i can see that the problem occurs during fusing process, the wrinkles are only on the upper/exit side of the fuser.... I changed almost everything in the fuser unit..... Can it be a problem in the paper registration??
                  • mgill96
                    • Aug 2012
                    • 5
                    have a look at your PTR unit. look for any missing or stuck upwards static fingers, the spikey ones that get caught when cleaning. I think ive had this cause the same issue your having.
