Ricoh Aficio 1515PS
Tags: None
Re: Ricoh Aficio 1515PS
If memory serves the MF model is a standard GW board so it can understand PCL and RPCS printer language, PS means it can also natively understand Postscript via an optional card.It's 106 miles to Chicago. We've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses.
Hit it. -
The Aficio 1515MF (B130) is a MultiFunction model and should include print, scan, and FAX functions. The Aficio 1515SP is not a valid model for North America, but based on standard Ricoh model labeling the SP indicates Scanner/Printer and might not have FAX function. Otherwise, the two are the same basic machine, i.e. same toner, PCU, developer, and parts.Comment
The next model up was a 161, followed by the 171, and finally a 201. All of these Aficio models were pretty much the same interface on the same frame for quite a while. Very popular and still a lot of them in the field.
I never recall a PS model to tell you the truth.Comment
http://www.copytechnet.com/forums/ri...ner-error.html
To which you responded with complete silence - and without as much as a "thank you" for our input.
So here we go again.....Comment
