The 60G hard disk is damaged, Is it support by using 120G hard disk
Aficio MP3350 Hard Disk
Re: Aficio MP3350 Hard Disk
The MP 3350B is the "basic" model. Copier only. For printing and monochrome scanning it requires the installation of the Printer Scanner Unit type 3350, EDP code 414401. It cannot be converted for color scanning.Comment
SP Mode 5853
Stamp Data Download
Push [Execute] to download the fixed stamp data from the machine ROM onto the hard disk. Then these stamps can be used by the system. If this is not done, the user will not have access to the fixed stamps ("Confidential", "Secret", etc.).
You must always execute this SP after replacing the HDD or after formatting the HDD. Always switch the machine off and on after executing this SP.Comment
