I have a Ricoh 1060 with no LCD display when main power switch is turned on. Also the open door and wrench indicator pop on within seconds after turning on main power switch. I can't see a code. There is no type of drive attempt by the copier. Checked all the fuses (fu101 - fu111). Tried pulling out all trays, fuser,duplex, disconecting RADF and finisher to se if one was causing a short.
I'm leaning toward a LCD board or Main power board.
What do you think???
