Ricoh Aficio 3800 C
  • pjpedro
    Ricoh Aficio 3800 C
    I had a SC 860 error ( i now is HDD problem), i have replaced the HDD, but i think the Hdd has a operative system or something else, because the copier say that i have no HDD in.
    if so what can i do for the copier reconize the new HDD?
    and how can i enter in the service program mode?
    tks in advance
  • copytec
    You must formating used HDD, before replace.
    • SGT_Snacks-64
      • Oct 2007
      • 157
      tks in advance
      Hi, right
      As far as I'm aware, with Ricoh's you can generally use any Hard drive "either a 2.5" or a 3.5"" and they do not need formatting. However, if the machine is not recognising the hard drive, it might be worth checking the master/slave jumper settings on the hard drive, and check all the connections.
      Having said that, I haven't done a Hard drive on this model, and don't have my Laptop to hand.
      Other than that, you've asked how to get into the Service Program mode, a Ricoh engineer/technician would have the Service manual, which states how to enter the Service program mode on these models.
      Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
      Asus P5E-VM HDMI
      4GB (2x 2GB) Corsair XMS Xpert II RAM
      ATi Radeon 4870 512MB GFX Card
      2x 74GB WD Raptor Sata HDD (RAID 0)
      500GB Seagate Barracuda Sata II HDD
      500GB Hitachi Sata II HDD
      600W500att OCZ PSU
      -TOTAL HDD SPACE 1148GB-
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        tks in advance
        Hi wecome to the forum, just check what
        sgt snacks-64 told you, HDD jumper to master, ricohs don´t need Hdd formating.
        If you know SC 860 is a Hdd error how can you not know how to enter service mode, are you willing to get into problems by going into service mode and altering something by mistake, very easy no this model due to its small limited display, you must know how to jump from one menu to another and back and also exit, be carefull this machine is very tricky you can easlly alter a SP without even knowing you did so, I think you should ask a ricoh tech for help.
        • pjpedro
          tks in advance
          • Jomama46
            • 2900
            HDD is the most likely problem, check the one you installed and make sure it is indeed OK.
            Next replace the controller board, next the PSU.
            sigpic
            A+; Network +; PDI+
            • miigaik
              Did you replace the HD with one of the same size? If no, maybe the HD is just too big for the printer, try one with the capacity not more than twice as large as the original HD
              • mowpro
                • Aug 2008
                • 43
                set the jumpers
                Did you set the jumpers on the hd for master
