Error code Ricoh mp 7500 sc 335
  • maj143
    • 55
    hi all
    i need help in ricoh copier MP 7500
    i make HDD all format and after that come code SC 335 i think it have to make laser program
    can any one help me and give me the sp mode for this ???
    • 37491
    Re: Error code Ricoh mp 7500 sc 335
    If you don't have one, buy a service manual.
    Search for the thread "Ricoh Goose's Guide 2013". In post 73 I attached the April 2013 edition of Goose's Guide. Download it and use it to do trouble shooting before you come here. It might get you the answer you need in seconds.
    Check for a loose connection going to the polygon mirror motor. Check fuse 111 on the PSU. Replace the polygon mirror motor. Replace the IPU.
    • maj143
      • 55
      the copier was working after clear all memory it come this code
      • khaled_abosere3@yahoo.com
        Head technical support
        • Mar 2012
        • 171
        SP- 2103- LD Power Adjustment DFU
        Note: This is an SSP mode. To enter SSP mode, push [Reset], enter "107", then
        hold down [Clear] for at least 3 sec. When you see "Copy SP" on the touch panel,
        press and hold down [#] then touch "Copy SP".
        001 LD-0 Adjustment
        002 LD-1 Adjustment
        003 LD-2 Adjustment
        004 LD-3 Adjustment
        These SP codes allow adjustment of the laser intensity for
        each of the four channels.
        [-55 to +64/-24/1]
        005 LD-0 Start/End
        006 LD-1 Start/End
        007 LD-2 Start/End
        008 LD-3 Start/End
        These SP codes allow adjustment of the start/end timing of
        the adjustments performed for SP2103 001-004.
        [0~1/0/1]
        From sevice manual.
          • 37491
          Why did you do a memory all clear? I hope you have the birth certificate or at least a recent SMC print out of either SP Mode or Non-default. If you don't, you will have fun getting everything properly adjusted.
          • maj143
            • 55
            my friend tech and he do memory all clear i dont know why but when he do it this code come on
            so i think its need a program but i dont know which one
              • 37491
              It is a component problem not a program problem. Read the first reply I made.
