Ricoh MPC5000 Part Transfer Assembly Holder
  • PJF
    • Jul 2014
    • 32
    Anyone able to help me. My MPC5000 parts manual is outdated it doesn't have the mod parts.
    I need to replace Transfer Assembly Holder D0894663 as the locator pin broke, which has been modded to D0894664, but the mod part doesn't have the locator pin. So Im guessing there's another part that needs ordering. Anyone able to shed some light on this ?
    • 37532
    Re: Ricoh MPC5000 Part Transfer Assembly Holder
    TSB D027/029 - 032
    If you have a machine with original Transfer Roller Case, you have to replace the entire assembly. D0256282 Case: AT: Ass'y, D0296288 Case: Transfer Roller, D0894664 Guide Plate: Transfer Unit: Holder, D0894665 Shaft: Holder: Rear, 04583020N Hexagon Head Tapping Screw: 3X10, D0894666 Drum Stay: Front, and 2 each 04583008N Hexagon Head Tapping Screw: 3X8. Once you have replaced everything, in the future you only have replace individual parts should they break again.
    • jonbonse
      • Jun 2009
      • 737
      TSB D027/029 - 032
      Hey, would you happen to have the TSB for this?
      • skynetto
        • Sep 2012
        • 257
        Here it is.
        C5000 mod.pdf
        • jonbonse
          • Jun 2009
          • 737
          Originally posted by skynetto
          Here it is.
          [ATTACH]34078[/ATTACH]
          Thanks!
          Does this apply to the C2800/C3300?
          • skynetto
            • Sep 2012
            • 257
            Yep. Same part.
              • 37532
              Here's the North American version of the bulletin;
              rfg057345.pdf
              • TayTayTheTechnician
                • May 2016
                • 51
                TSB D027/029 - 032
                There is a kit available too. I'm going to try it out.
                Ricoh KIT-C2800 TRC Transfer Roller Case Kit, Genuine (K0054)
                  • 37532
                  You might be asking for more costs than the kit savings. Follow the bulletin exactly.
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Fitting the original mod parts is a cheap repair.
                    Works out to $150(AUD) plus labour.
                    • fshead
                      • 2376
                      i had a few of these break and was shocked at the cost for the metal stay/shaft and metal side piece.
                      IT was like $70 for the two small pieces and the two plastic housing were cheap,maybe $50 for both.
                      I ended up making a few spares wth a grinder and drill.
                      I refused to pay that out of principle...........
