removing a postscript 3 option from a mp 6001 to a different mp 6001>>confused here
  • fshead
    • 2376
    hi,
    i have only sold one b/w ricoh copier with postscript 3 in the last 10 years.
    i just read thru the manual and now i am more confused wth "merging sd card".
    i picked up a mp 6001 wth postscript 3 option but i dont need it on this sale.
    i did try just removing the postscript sd card from the 2nd slot,and after plugging in repowering up.
    i got a message to ck wth administrator to install sd card in correct slot.
    machines comes to ready..
    can i swap print/scan sd card from a nonpostscript machine to a postscript machine.
    the ps3 sd card was in the 2nd slot.
    thnx
    • 37503
    Re: removing a postscript 3 option from a mp 6001 to a different mp 6001>>confused he
    Every model has its own PS3 SD card. It the SD card was from a 6100, it can only be used in a 6100.
    • fshead
      • 2376
      not sure if you are following my post
      i have a mp 6001 with print/scan and added option the postscript 3 option.
      there is only one slot on these machines for options wth the 2nd slot for service/firmware updates.
      i am staying model for model mp 6001,just looking to swap option to a different unit.
      the merging sd cards has me confused and i dont want to do something i cant undo..
      • Iowatech
        Not a service manager
        • 3930
        I think there is something in User Tools you need to turn off so that the machine stops pestering you about the removed PS3 card. It's been a while since I read about that so I don't remember where it is, sorry.
        If the PS3 card was in slot 2, the system card in slot 1 should be OK when the PS3 card is removed. If I remember correctly, the PS3 card needs to be in slot one if the system card has been merged with it. Slot 2 should be empty if there are no other applications added to the machine then.
        • fbkhan3
          • May 2012
          • 421
          you can copy the Printer/scanner Applications to a PS3 Card.(yes you can use Printer/scanner card from other Machine if it has not been merged before).
          1:PS3 Card in Slot 1
          2: Put the Source SD card in Slot 2 (Printer/Scanner Card)
          3:Copy Sp/Appli Move SP5873 -1.
          This Process will Copy Printer/Scanner Application to PS3 card when done take out the card from Slot 2 and save it somewhere in case if you need to undo the process in future .Slot 2 should remain empty because it's service Slot.
          HTH
          Regard's
            • 37503
            HTH
            Regard's
            This pretty much covers it. First step should be to turn the machine off. Turn it back on after the SD cards are in the slots. After the Printer/Scanner Application has been copied to the PS3 card, turn off the machine, remove the Printer/Scanner card and store it with the 6001.
            • fbkhan3
              • May 2012
              • 421
              X2..
              But you can't swap PS3 Card once installed ... Not even Model to Model.
              Regard's
              • fshead
                • 2376
                on my unit the print/scan card was in the top slot,and the ps3 below it on the "service slot"..
                i cant understand how one machine will know if an option was merged before..or once merged is the card
                a print/scan/ps3 card?
                on my machine wth ps3 installed the top slot did not have the ps3 card but the print/scan card..
                again this was a lease return wth super low count 43k..
                normally i would mess with the cards but i dont want to muck up a controller or a sd card
                • mikadonovan
                  • May 2008
                  • 2931
                  It's been my experience that is you stick a PS3 card that was installed on another machine into a like model it will indicate on the display that the card has already been installed on another machine.
                  NEVER ASSUME ANYTHING
                  • fshead
                    • 2376
                    i ve been told that i can do a Undo Exec .SP5873-002 (Undo Exec). on original machine wth original print/scan card and ps3 card .
                    then i merge the print/scan to the ps3 card on "hopefully" a different mp 6001....
                    nothing is like the old days of swapping out......
                    • fshead
                      • 2376
                      could not do the UNDO sp5873-002..
                      tried wth the ps3 card on top slot and wth sd card not locked..
                      ended up buying a new card................
                      what confused me is seeing others selling USED ps3 cards online
                        • 37503
                        Let the buyer beware!!
