MP1350 - SC990
  • mdfurqan2012
    • 194
    [Error Code] MP1350 - SC990
    Machine generates sc990 in mp1350 at power on, I am trying to use this machine after 25 days when I start this machine machine generates sc990 I try to power up without hdd, recheck bcu to ipu cable and connector but every time when I power on machine generates sc990
    • 37488
    Re: MP1350 - SC990
    If you have a copy of goose's guide, use it to look up your errors. If you do not have a copy, it is post to a thread in this forum, find it and downloaded it.
    • 88hawkfan
      • Jun 2014
      • 76
      Re: MP1350 - SC990
      SC 990 Software error - Replace system sd card 8/8/2008 Helpful
      SC 990 Software error - Change paper direction for 8.5x11 8/8/2008 Helpful
      SC 990 Software error - Check SC history for additional codes at sme copy count 8/8/2008 Helpful
      SC 990 Software error - Controller defective 8/8/2008 Helpful
      SC 990 Software error - Reload firmware 8/8/2008 Helpful
      SC 990 Software error - Replace NV Ram 8/8/2008 Helpful
      SC 990 Software error - Replace hard drive HDD 8/8/2008 Helpful
      SC 990 Software error - Replace network card 8/8/2008 Helpful
      SC 990 Software error when printing more then 16 pages - Update system firmware to V6.03 or higher 10/24/2008 Helpful
      SC 990 SC 990 when a large document is printed from doc server. SP-Mode 5182 HDD page management. 1/6/2009 Helpful
      SC 990 Software error- save NVRAM, clear memory and reload NVRAM. 7/10/2009 Helpful
      SC 990 SC 990 only while 2 side booklets copying - replace IPU 3/11/2010 Helpful
      • mdfurqan2012
        • 194
        Re: MP1350 - SC990
        thanks for your tips
        but issue is not solve yet
        further detail of SC-990 is
        File:ENG:bios
          • 37488
          Re: MP1350 - SC990
          Originally posted by mdfurqan2012
          $further detail of SC-990 is
          File:ENG:bios
          The best place to get a complete answer as to what these specifics mean is from a Ricoh engineer. As a field technician, all I can tell you is that the problem is in the engine portion of the firmware. Either corrupted firmware - reload or a bad NVRAM, IPU or controller.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            Re: MP1350 - SC990
            sounds like it may not be able to do process control since it's been unused for 25 days or so. But slimslob is right you need a Ricoh technician to troubleshoot this and restore the machine to working order...........
            Mystic Crystal Revelations
            • mdfurqan2012
              • 194
              Re: MP1350 - SC990
              Kindly help me to solve my issue and also guide me goose's guide
                • 37488
                Re: MP1350 - SC990
                I have already uploaded it once. I am not going to uploaded it again unless Ricoh makes a newer version available. Scroll through the Ricoh, Savin, Gestetner, Lanier forum and find the post Ricoh Goose's Guide. Goose Guide can be downloaded from post 73 of that thread.
                • mdfurqan2012
                  • 194
                  Re: MP1350 - SC990
                  Finally I resolve SC-990
                  First I changed bcu board from another machine for testing purpose only after replacing bcu board machine becomes ready I check some copies and check printing also.
                  I wash bcu board which gives SC-990 by alcohol and after satisfaction that all the liquid becomes dry then I install it in the machine and its work, machine becomes ready without generating sc-990.
