almost blank prints
  • toshiba
    • Dec 2006
    • 58
    almost blank prints
    In ricoh MPC4500, all prints are almost blank and only in rear side of the paper around 10mm image appears at normal clarity. Image in the drum also the same. Pbm could from laser unit; some mechanical alignment pbm and I tried following.
    1.Upgraded all firmwares.
    2.Removed the metal shutter of laser unit.
    3.Changed the position of laser unit little away from its original position.
    But no result. Any suggestions? Please!
  • SGT_Snacks-64
    • Oct 2007
    • 157
    Not sure, but I'd be checking the Drums and Image Transfer Belt and see if they're in correctly/working properly/not broken
    I've had the Image Transfer belt rip on one of these before, wasn't as bad as what you have but could always be a factor.
    Is this happening on all colours or black only?
    Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
    Asus P5E-VM HDMI
    4GB (2x 2GB) Corsair XMS Xpert II RAM
    ATi Radeon 4870 512MB GFX Card
    2x 74GB WD Raptor Sata HDD (RAID 0)
    500GB Seagate Barracuda Sata II HDD
    500GB Hitachi Sata II HDD
    600W500att OCZ PSU
    -TOTAL HDD SPACE 1148GB-
    • toshiba
      • Dec 2006
      • 58
      MPC4500
      It happens in all colors and tomorrow I'm swapping the transfer belt unit.
      • SGT_Snacks-64
        • Oct 2007
        • 157
        Ok, I forgot to ask as well, does this happen on print outs or just copying "Print a counter sheet/SC test chart and check".
        Asus P5E-VM HDMI
        600W500att OCZ PSU
        • leo34staffs
          copierman
          • Aug 2007
          • 503
          check the laser shutter as on the 2500 range this problem was known with early firmware
          Networking skills are advantageous but use of a 3m vacuum cleaner is essential
          • toshiba
            • Dec 2006
            • 58
            I swapped laser unit also and its not defective, I think this can be drum grounding pbm or bias pbm. I removed laser unit shutter also.
            • toshiba
              • Dec 2006
              • 58
              and it happens with all types of prints both in color and mono.
              • SGT_Snacks-64
                • Oct 2007
                • 157
                Yeah that's a possibility. You could also check the Charge Rollers on each PCU, I think you can access them quite easily, give them a clean with a damp cloth or something, see if that atleast changes the fault.
                Asus P5E-VM HDMI
                600W500att OCZ PSU
                • toshiba
                  • Dec 2006
                  • 58
                  hai friends,
                  thanks for your suggestions and at last the pbm was due to the charge leak in drum unit and I replaced the PCUs and the issue got solved. Strange cause this is!
                  • Jomama46
                    • 2900
                    what is a "pbm"?
                    sigpic
                    A+; Network +; PDI+
                    • iMind
                      Vacuum Cleaning Expert
                      • Mar 2008
                      • 1116
                      Originally posted by Jomama46
                      what is a "pbm"?
                      pmb, it sounds like problem, hehehe
                      "at last the pbm was due to the charge leak in drum unit"
                      • verderacer
                        • May 2008
                        • 158
                        what is a "pbm"?
                        I am far from having the best grammar and that is mostly due to the fact that English was not my native language but im with Jomama on this one. Why cant people just use the proper word and save everybody guessing. Has society just degraded to the point and started accepting illiteracy as normal???
                        Ricoh & Microsoft may pay the bills but Un*x saves my ass every day.
                        MCSE/CCNE/ENS and other crap...
                        • SGT_Snacks-64
                          • Oct 2007
                          • 157
                          Come on man, this IS the Internet after all :P
                          Asus P5E-VM HDMI
                          600W500att OCZ PSU
                          • Kopyrtek
                            Copier Psychologist
                            • Jan 2007
                            • 407
                            Short for problem
                            • Kopyrtek
                              Copier Psychologist
                              • Jan 2007
                              • 407
                              Looks like there were two pages on this thread and i only saw the first one.I do text alot with my techs and they seem to have all the short cuts to keep texts to a minimum and it doesnt bother me till i cant figure out what they are telling me.
