New machine, just installed. The client calls me and tells me that the machine generates code sc 670 turns off and on again, the machine goes for a bit 'and then generate the code again. I solved it by replacing the BCU board
I have also been lead a merry dance on a Ricoh MPC3003 with SC670..........
It turned out to be the IPU board,
I've also had it when the controller board and Memory Dim have been faulty.
All I can say say is keep an open mind and use all the info you have to diagnose the fault for SC670 as it appears to be triggered by numerous faults.
