Savin 9922/9927, Lanier 5222 oldie, need fuser core
  • buzz
    • Aug 2013
    • 288
    Anyone with a good used fuser part number A2677281?
    The customers fuser frame is cracked and brittle, with screw holders falling out.
    I know this is an old machine, but was wondering if I could keep these guys going with some spare parts.
    lmk
    thanks!
    • 37513
    Re: Savin 9922/9927, Lanier 5222 oldie, need fuser core
    Have you tried to order a new lower frame Part # A2674027. That is normally all that needs to be replaced. It is usually the result of the lamp connections overheating due to the screws not being tightened properly.
    • lef3pap
      • Jan 2012
      • 32
      It would be really expensive to order a full fusing unit.Try replacing the lower part first.I guess that the hot roller base broke (that is the common problem) so the solution is changing the lower fuser frame.If you need the part number ask for it
      • sandmanmac
        • 3981
        I actually have a Brand new fuser base unit (lower frame) P/N A267 4072, which as mentioned, is probably your best option.
        It's just collecting dust, so PM me if you're interested and you can't source it locally.
        AF270 - Lwr Fuser.pdf
