MPC 3502
  • Bennybhoy
    • Sep 2014
    • 5
    MPC 3502
    Hi,
    have an issue on this machine where if you use rotate sort, on large runs, copies coming out short edge first, sometimes have a dirty black mark. Dum and Dev unit have been changed, as has transfer sep roller. any ideas ?
  • rosspt
    • Mar 2012
    • 92
    Re: MPC 3502
    Try a forced jam when you know a page that will come out dirty is in the paper path by opening a door at the right time. Then you can see if the dirty mark is on the page before or after the ITB or the fusing unit or wherever. An interrupt jam might help pin-point the issue or at least narrow it down.
    • redneckstylin
      • Sep 2011
      • 173
      Re: MPC 3502
      check fuser entrance guide
      • SargeNZ
        • May 2012
        • 263
        Re: MPC 3502
        Bump the fusing temps but 5 or 10 degrees. These machines sometimes have cold offset issues.
          • 37491
          Re: MPC 3502
          It could be the ITB or ITB cleaning station. If it is the trailing edge, it could be the charge HVPS.
          • Zeldaman
            • Mar 2011
            • 946
            • Bennybhoy
              • Sep 2014
              • 5
              Re: MPC 3502
              Thanks for all the input lads, turned out to be the ITB
