Ricoch C811 not recognise new toner cartridge
  • isladelobos
    • Aug 2025
    Hello.
    The Ricoch Aficio SP C811DN.
    I put one new original K toner cartridge but in the lcd the message is ever "please replace the K toner".
    Some ideas?
    The new toner is original and ever used.
    The rest of toner cartidges are fine.
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Ricoch C811 not recognise new toner cartridge
    Faulty toner pump / clogged k tube probably.
    A easy fix if you have the correct part.
    • isladelobos
      Hi Cipher.
      You have the instructions for replace the pump?.
      I localiced into the fusing unit compartment.
      • Cipher
        • May 2006
        • 1309
        Yep, contact your local Ricoh dealership and place a service call.
        A trained engineer should do the work and check the rest of the printer over.
        It could easily turn into a messy job or you may damage something else if you don't know what your doing.
