mpc2051 much different than a mpc2050?
  • fshead
    • 2363
    hi.
    looking for some lot meter lease return low end color units and was wondering
    is there any major difference in the mpc2051?
    looks like drum units and transfer units are the same.
    outside of boards are they interchangeable?
    any improvements for scanning?
    thnx
  • Zeldaman
    • Mar 2011
    • 946
    Re: mpc2051 much different than a mpc2050?
    Hi there!
    Some boards & the fuser are different, also the fw.
    Greetings...
    • lukeh
      • Jun 2012
      • 43
      Drum units are different and fusers
      • fshead
        • 2363
        just cking online i saw that mpc2050,mpc2550 and mpc2051 use the same drum and transfer unit..
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          Roger that!
          Greetings...
          • fshead
            • 2363
            Originally posted by Zeldaman
            Hi there!
            Roger that!
            Greetings...
            ok
            am i right or the other post re drum interchangeability?
            what is the fw?
            • ruben
              The New Guy
              • Oct 2012
              • 1203
              Fuser, firmware and boards are different. Everything else is the same; drums, ITB, PTR, etc.
              • fshead
                • 2363
                thnx
                i try not too over complicate what parts i need to have in hand.
                • ruben
                  The New Guy
                  • Oct 2012
                  • 1203
                  Originally posted by fshead
                  thnx
                  For these models I highly recommend you carry at least one PCU and a fusing sleeve (called 'belt' in the manual but it is a sleeve). These models are prone to BK drum damage and the sleeve goes quite quickly, once it does the machine will make a horrible groaning noise. At first I thought it was the paper friction pad, but it nearly always the fuser sleeve.
                  You can use the older friction pads B0XX-2710, can't remember the exact code, instead of current ones. (Older ones are cheaper).
                  Also, always carry a duplex entrace guide, the teeth break easily.
                    • 37378
                    Ruben is correct. One other thing, The black toner cartridge is different and is not interchangeable. The color cartridges can be interchanged. The color cartridges for the MP C2551 have a target yield of 9500 as opposed to 5500 for the 2550.
                    • fshead
                      • 2363
                      thnx
                      These models are prone to BK drum damage>>
                      is that more on the mpc2051 or both 2051 and 2050?..
                      re:black toner cartridge is different and is not interchangeable<<thnx
                      thats good info too.
                        • 37378
                        If a loud vibration is heard while paper is being fed from Paper Feed Tray 1 or 2, use friction pads D1052722. See TSB D037/D038/D040/D041 - 044.
                        • shutch7
                          • Jun 2013
                          • 15
                          We only order MPC2051 black toner and break off one tiny lug on the bottle which makes it interchangeable between both models as the price is similar, and higher yield for the 2051
                          • ruben
                            The New Guy
                            • Oct 2012
                            • 1203
                            Did they mod the material? I haven't had a chance to check for mods. Been pretty busy.
                              • 37378
                              They actually added a dry lubricant to the points where it contacts the tray base. Surprisingly, it seems to work.
