mp c4501
  • CrapAimer
    • 296
    mp c4501
    Hi all looking for some help before I order a board
    Have a machine which has come up Black Toner almost empty, machine working ok tried replacing cartridge but just the same, Toner being supplied ok just saying replace toner cart, sure I have seen this before
    Any help appreciated
    George
  • Max
    • Oct 2011
    • 546
    Re: mp c4501
    I would reset the copier back to factory default 1st before you order any boards
    • halbrandenburg
      Bypass Tray Expert
      • Sep 2011
      • 92
      Re: mp c4501
      After making sure you have all of the network settings at hand, and the address book backed up (if applicable).
      • rsyarcia
        Hair Straightener Tech
        • 711
        Re: mp c4501
        clean the toner pump including the tube. if still the same change first the toner pump.
        Nobody is perfect..
          • 36796
          Re: mp c4501
          Try running about 100 test prints using the "Checker Flag" test pattern. If the image density decreases during the test run, you most likely have a partially clogged toner supply system. If image density increases, you have a bad development unit, TD sensor bad.
          • mikadonovan
            • May 2008
            • 2931
            Re: mp c4501
            Performing a RAM clear is not the way to troubleshoot an "Add Toner" condition.
            NEVER ASSUME ANYTHING
            • nmfaxman
              • 1702
              Re: mp c4501
              These machine will display an almost empty when it gets low.
              Don't replace it until it says to replace it.
              This gives the customer time to order one before it dies.
              If it bothers you change sp code 3045 to a 0.
              Never reset a machine to factory, there is no reason for it.
              • Max
                • Oct 2011
                • 546
                Re: mp c4501
                My bad, I assumed you have done the all the basic stuff1 st, ie pumps,pipes new dev and so on.
                • Gift
                  • Mar 2011
                  • 2444
                  Re: mp c4501
                  You can perform an engine reset but not without doing a NV-Ram backup before^^
                  Back then we had several MPC6000 with bad toner end/replace toner messages after installing new OEM toner. No chance to get rid of the message unless you try another, new toner or actally did an engine reset and restore the NV-Ram backup you hopefully didn't forgot. Not shure why the error didn't re-occure after data restore but the result is what count's.
                  False near-end conditions doesn't justify these actions. Just ignore them until the machine detects toner end - in this case the bottle should be empty of course.
