Ricoh MPC5501 " waiting for print data"
  • Hadster
    • Aug 2011
    • 264
    Customer is trying to print from Printshop 22 and it is taking forever to print. (5 to 10min) Upgraded software and even tried new printer board with same result. I'm not much of an IT person so any help would be appreciated!
  • Moza
    • 232
    Re: Ricoh MPC5501 " waiting for print data"
    Could do with a bit more info ? How big is the file they are tying to print, are they printing direct or through a server, what print driver are they using, what is it like printing from other application.
    • Hadster
      • Aug 2011
      • 264
      3MB is the size of the file. Printing from MS Word is right a way. PCL6 driver not windows driver. Using server. Should I try a USB cord to see if there is a difference?
      • Moza
        • 232
        Have you tried printing direct rather than through the server ? Can you also check what "Ethernet Speed" is set to in [System Settings] then [Interface Settings]
        • Hadster
          • Aug 2011
          • 264
          Ok, brought in MPC5000 under same conditions and works perfectly. Checked internet speed on MPC5501 and was set to 100bpms full duplex. The 5000 is set to auto select...just sayin.Thanks
          • Moza
            • 232
            Ok just set the MP C5501 to auto and see if that works
            • Hadster
              • Aug 2011
              • 264
              Bam! (Auto select) speed was the issue! Spitting them out at lighting speed. Sweet! I don't feel stupid at all. hint
              • Hadster
                • Aug 2011
                • 264
                Thanks for your help Moza!!!!!!
                • Moza
                  • 232
                  Your welcome
