Ricoh MP201 spf
  • gspanihel
    • Oct 2014
    • 5
    Ricoh MP201 spf
    Making popping noise inside conveying unit. Look in side on the right side but don't see anything out of place or loose?? Hoping someone might have had similar problem.
    ~Greg
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh MP201 spf
    Sometimes a popping noise occurring from the right side of the machine is caused by the fuser. This occurs when the fuser is past it's PM cycle, or the bearings need lubrication with a high temp grease.
    NEVER ASSUME ANYTHING
    • redneckstylin
      • Sep 2011
      • 173
      Re: Ricoh MP201 spf
      side door little blue gear change that
      • teebee1234
        • 1670
        Re: Ricoh MP201 spf
        It's almost always the transfer roller frame is cracked around the front bushing of the transfer roller, the pressure when it's against the drum causes it to jump. Don't bother trying to glue/repair it, just replace it.
        • Cipher
          It's not easy being green
          • May 2006
          • 1309
          Re: Ricoh MP201 spf
          Another vote for the transfer roller / bushings being the cause.
            • 37493
            Re: Ricoh MP201 spf
            [ATTACH=CONFIG]26913[/ATTACH]
            Same here. I have had the bushings get cruddy and cause the roller to bind or turn slowly. When it binds, the gear on the end starts jumping teeth where it contacts the gear on the drum. Rather loud noise. Clean all the toner out of the bushings and clean the shaft. When it comes back, replace the roller assembly.
            • mikadonovan
              • May 2008
              • 2931
              Re: Ricoh MP201 spf
              I havent run into this yet. I'll keep my eyes open for this. Good info.
              • Gift
                • Mar 2011
                • 2459
                Re: Ricoh MP201 spf
                YOu can ask the customer if the noise stops during pushing the right door a bit during printing. If yes it's definetely the transfer roller bushing. MP301 transfer roller does also fit - bushing matarial seems modified (some white plastic).
                • Zeldaman
                  • Mar 2011
                  • 946
                  Re: Ricoh MP201 spf
                  Hi there!
                  Agree with all posters. By the way, only the MP 301-roller is availible, fits like the old one.
                  Greetings...
